5 minutes ago, gary112 said:
Yes
Yes but No  (  but yes it will remove shit an yr natural oils from yr skin which will split n become infected ) but Yes you dont need to listen to me. K
cut 'n' paste
Swarfega[emoji768] Orange
Features & benefits
  • Advanced Formulation: Uses a blend of non ionic surfactants to remove oil, grease and general soiling quickly and efficiently
  • Contains natural cornmeal scrubbers which give a deep down clean and gently lift ingrained soiling without damaging the skin
  • Solvent-free formula helps prevent drying out of the skin
  • The rich creamy lotion quickly rinses off the skin leaving no greasy after-feel
  • Contains glycerine and wheatgerm extracts to help moisturise the
Olive oil user here.
I think these microbeads may have been plastic in the past which obviously end up in the sea, so interesting to see Swarfega mention cornmeal scrubbers.
Not sure what’s going on..
Anyway, good old fashioned soap is ok for me, takes a little time, but once it’s been in hot water for a while it comes off easy enough.
