These things are good if they will fit down the hole, be warned tool station sell 2 sets but really it’s 1 full set in 2 packs and Sod’s law says which ever set you get you will need the other (I’ve got both for that reason ? )
WWW.TOOLSTATION.COM
Securely grips and removes stubborn nuts and bolts. Reverse spiral flutes bite down for maximum gripping power. 3/8” square drive for use with hand ratchets, impact wrenches and air...
Edit: This is the other half of set, hey all fit in the box from first set
WWW.TOOLSTATION.COM
Unique design that securely grips and removes stubborn nuts and bolts. Reverse spiral flutes bite down for maximum gripping power. High quality carbon steel ensures longer life...
Edited by Will C
Second set
WWW.TOOLSTATION.COM
WWW.TOOLSTATION.COM
I've used these a fair bit. They are great tools.
Torx bit is the best option. But when not available in the middle of nowhere I have used a small diameter piece of wire placed on the side of Allen hole and then driven key in.
It is usually a case of smacking in the next size Allen, a slightly larger AF Allen or a suitable torx bit. You could do this and try a rattle gun on it for the most undoing impact. A flat screwdriver may also do it otherwise as someone earlier said, cut around the bolt and buy a new cover.
If all else fails, drill the head off, remove the cover and then cut a slot in it, heat the fecker up and undo it with a screwdriver......there is always a way:thumbup:
Ease out reverse drill bit! so the drill works by being lefthanded bit
One issue you could find if into Alloy and hasnt been out for a long while is Electrolysis as mixed metals ie Alloy and steel add moisture=them growing against each other so things seize up.
BINGO! - Torx bit, medium hammer persuasion, small ratchet, lots of downward pressure. So, got the muffler off & as suspected carbon build up outside exhaust port explained lack of oomph. Cleaned off & now revving right up. Love that exhaust crack you get when things are clean.
Thanks a lot folks - getting support here always gives me a second wind to have another go at my maintenance / repairs.
Glad you got it out as to the "lots of downward pressure" I have found the old fashioned impact drivers are useful to give the downward force plus the torque impulse simultaneously for future reference
