25 minutes ago, Dan Maynard said:
2 hours ago, AHPP said:
Fixed with higher heat. Popping in seconds, way better results.
Read more
Not sure if it's the reason but butter bubbles and burns at a lower temperature than oil, I've only ever used oil.
Next batch I do I'm going to pop it in oil and then melt butter and toss in the pan off the heat.
Result!
I find popcorn a bit like bacon. The eating of it doesn't quite live up to it's tantalising smell as you cook it.
Lovely hanger steak with some chilli bratwursts from Aldi. Cooked over birch [emoji39]
You were doing so well until I noticed the nice knife on the ceramic plate.
I hope this doesn’t go down like an undercooked piece of fish……..
But I’ve fairly recently discovered the recipe's by a man called Scott Baptie. Nearly every single one I’ve made has been delicious, and also proving a hit with the particularly fussy Mrs. Worth having a look if like me you get stuck in a rut with your food and cooking.
Weve enjoyed his beef stifado tonight, very tasty even though I forgot the red wine 🤦🏼‍♂️
The old opinal sharpens up a treat so no bother. I like the metal covered enamel plate as they don’t melt 😉
I'd like some wooden plates. I often eat off boards. Need a lathe. Need space for one first.
