Opico Skidster or sherpa mini loaders
swinny
Brilliant thread this, starting a bit of a shopping list for a wheeled stand on machine, is anyone using the stag machinery log grab? Be good to hear any views on it, and if I'm right thinking it and the klou  grab are the only two fixed type grabs available for the smaller machines with a free float setting for skidding? Thanks
11 hours ago, Bayhales said:
is anyone using a logsplitter with there mini loader?
I use a drillcone from time to time but always feel, that the few logs are not worth the expensive machine hours of the mini.
This is the only reasonable use I see if you have a yard you can mess up:
https://youtu.be/KVffHmpSPOs?t=395
Edited by marne
I have an Opico mini skidster m10x. I looked into a log splitter for it. In the end I decided to buy a petrol stand alone log splitter so then I could carry it to where I wanted to work with the loader, then utilise the grab on the loader to lift up stems and crosscut them into rings off the ground etc
The splitter running off your loader will tie your loader up and it won’t be available to shift timber about etc.
That’s how I see it.
A loader as a base unit makes an expensive splitter!
You can buy a decent splitter with a petrol donkey engine for about £1.5k.
Or even a hobby 7t one like mine for a few hundred, but that still does about 50m3/year.
