Hello guys
Β
Could anyone recommend a decent tap and die set please? I know cheap sets should be well avoided but I’m not sure at what cost they become good? Any help would be great - I could have done with a set yesterday!!
Β
Thank you.
41 minutes ago, Gerbutt said:
Β
Hello guys
Β
Β
Thank you.
Β
Any taps and dies made by DormerΒ  will serve you well .Β  Most tool rooms use Dormer .
Thanks chaps! Does the kaliber set go big enough to sort out a bolt with an 18mm head that’s stripped the thread it goes through?
I’ll have a google of the dormer thanks.
Wowzers they are expensive!! I think they might be a tad overkill for me, mine would be for now and then - but still want to be respectable [emoji106]
You may be able to buy a single size tap from eBay for a few quid. Β You can even make one from a high tensile bolt if you are stuck - it just takes a couple of minutes.
18mm is not a common size head- could be anything. You will need to corectly identify thread, both size and pitch. Furthermore, you can't just run a die through and expect all to be well with the situation above. You need to either drill out and retap to a larger bolt, or drill out and tap to fit a helicoil.
Β
I've never spent Dormer money on taps and dies.
3 minutes ago, doobin said:
Β
Β
If you ever worked in a " trade shop " tool makers that would be all you ever used .
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
