13 hours ago, Joe Newton said:
The amount of tree surgeons who quote block paving is impressive ?
"cos Der is tree of us ye eeejit !" ;) k
On 17/06/2019 at 23:53, Jwoodgardenmaintenance said:
?? It's only a days work for 2 men? Works out £79.45 m2 all depends on prices in your builders merchants as well ect but still seems high ?
Jack
Plus muckaway, plus materials, plus profit (it's not a dirty word you know)
Spons outdoor works 2018 says £65/m for Marshalls single size blocks 60mm thick laid upon a proper sub base 150mm thick. Includes excavations. So that's £1170 for 18m2
Kerbs are £22/m for a header course- call it 9m? £198. £1368. Plus vat.
Hope that helps.
Edited by doobin
Hope that helps.
Muck away is included in the £25 m2 the kerbs are already in mostly just a couple of pin kerbs along the back so maybe £18 for them and a couple of bags of sandy gravel and cement £15 and the blocks don't need to be 60mm it only needs 50mm then there's no rules to say it has to be Mot type 1 I use 10mm recycled aggregate on budget jobs @ £6 a ton I use a wagon to remove waste I pay £65 for 4 ton soil removed and 4 ton sub base fetched in at a 230mm excavation that's 8.1 tons if it is 18m2 so £130 then there's sand 1 ton of sand  £16 per ton  does 8m2 at 25mm thick so that's £32 then the blocks don't sink and then there's the blocks budget blocks are £4 m2 so that's another £72 and silica sand is maybe another tenner and if you don't have the tools for instance £50 for a 3 ton digger then another £30 for stihl saw and whacker then weed membrane is £45 for 50m2 roll and finally labour at £300 for 2 men for a days work so the £450 for materials total is £392 + £300 labour so the job can be done on a budget for £750 & out of that there's £358 Labour paid all In all not a bad wage for a days work I'd of said
I've re read this if I have missed anything please feel free to say this is all off top of the head
Jack
Edited by Jwoodgardenmaintenance
Just to remember this is a budget job marshals products are a lot more expensive and buying sub base and sand from a builders merchant is more expensive than loose load from a quarry
Jack
I used to think like that. Then I realised that you need to make profit to get anywhere in business.
What godforsaken place are you in where a wagon driver will even turn up for £65, let alone take away 4 tons and bring the stone?
10mm recycled aggregate is for pipe bedding, not a base. A base needs the perfect amount of fines to bind properly. Recycled type 1 is about £20 a ton here in the south and to be honest virgin type one is only a few quid more and far more consistent.
I own my own diggers and keep materials in bulk loose in my yard. Still wouldn’t dream of doing a job as cheap as that.
Edited by doobin
The same place where you can get a 3 tonner for £50...... Admittedly there are massive regional variations but even so that’s mates rates at best.
When there is so much competition your fighting to survive to put food on the table I'd rather have made £300 ish day rate than had £250ish a month dole and with the sub base I've been and visited jobs I done 3-4 years ago and they haven't moved
I have always compacted it in 3 inch increments to get ultimate compaction and max 25mm bed of sand so it doesn't sink or crown
I can get type 1 with the binder in for £21.60 Inc vat a ton but on a budget that's 3 ton of crusher run so it's just a matter of customer and situation for work at the time
With the wagon it's a 7.5 tonner and he takes the topsoil away screens it and then sells it in for £25 a ton so doesn't charge (helps that I get on with the fella as well) and I'm in Maryport North West Cumbria
Jack
Why do you sound so surprised? How much are they in your area? It's off a local plant hire firm I use £40 for a 1.2 micro or 1.5 mini and £50 for a 3 tonner then £80 for a 6-8 tonner but you get it with a full tank of diesel and it goes back with one and if you break it you fix it
Jack
