  • 2 months later...
No where as bad has your cut but I was up a cedar cutting the lateral branches and only noticed I’d cut my arm when I felt my hand getting wet in the glove from the blood. Silky Sugoi are very sharp.
Hey guys,
Had a small accident in a spruce tree on Wednesday. 25 foot up the main trunk during a take down, stripping the lateral branches with the silky, cut a branch on my right side from the topside until it swung down and hung on its last fibers.  Grabbed to hold the branch with my left from the underside and proceeded to finish the cut off with my right hand from the topside again. The final cut went through far easier than expected and the final destination of the blade ended up hitting the topside of my wrist/forearm with some pull motion. Took a quick look as soon as it happened with blood squirting from the cut, got myself down from the tree asap and got my lad to get the first aid kit and the customer rushed me to A&E. The result of this silly mistake ended in 4 internal stitches. It had cut to muscle and cut a superficial vein and I have 9 external stitches. Thankfully no tendon damage and I should be back to work in a few weeks.
Keep safe guys!
I'm more questioning of your tiny pink opened toed slipper bottom right of this shot....cheeky
On 31/05/2019 at 23:14, Ian C said:
Be a mear flesh wound in Yorkshire, put a plaster over it and crack on !
what sort of Yorkshire man are you?  Impostor says I - bet you drink tetleys and put the heating on instead of a jumper as a true Yorkshire lad would have packed the wound with sawdust an gravel, topped off with a bit of moss and held in place with a grubby handkerchief  if need be- and if it got a bit funky, rinsed out with a bit of spit and best bitter when suppin after the days job - waste good money on plasters? - no yorkshire man i know ever would!
  • Haha 3
But the "best bitter" favoured by Yorkshire men is worthless enough to use for washing? ;-)
1 hour ago, jamallio96 said:
But the "best bitter" favoured by Yorkshire men is worthless enough to use for washing? ?
Ouch!
Anyway OK for washing, like weak water, tis the antiseptic element that is missing, that would require actual alcohol?
P.S.
Joking aside one of the best draught bitters I ever quaffed was Theakstons best bitter, at 3.8%,(@ the Fat Lamb, Fell End Cumbria, near Tunstall tractors ) but just "perfect" to allow me to enjoy 4 pints, without being do-lally.
Edited by difflock
Try telling the youth of today that , they won't believe you . ?
Edited by Stubby
