I am looking at a Hakki Pilke Eagle to help meet my own and some friends firewood requirements. I need to be able to produce 50cm long logs for a log boiler and 25cm ones for standard wood burners.  Up to this point I have done this manually, buying wood in the round (birch or beech) in 3m lengths a trailer load at a time and processing using a chainsaw and a rather slow hydraulic splitter.  So my questions:
1. Will that processor handle 50cm logs
2. Will it be significantly faster to justify costs
3. Is there a more suitable model for my requirements  - I am probably using close on 10M3 of wood a year + 5M3 for others
I dont generally like buying processed wood as I have had some right cr*p and also difficult to get 50cm logs
Cheers
Cheers - I did see that but it looked to me that you could cut the logs to virtually any length , I just wondered if there was an issue using a screw splitter on the longer bits of wood.
It will depend greatly on the wood you get. We had a screw type splitter but I had endless trouble with fibrous bits holding together and having to have a hatchet handy to finish the job. If you have some nice straight sycamore that just goes pop when you show it a splitter you will be fine regardless of the length.
In all honesty for the 15M3 you are talking about processing you'd be miles better off hiring someone with a mobile processor for a day and save yourself a lot of money
8 minutes ago, andy cobb said:
If you have your own power source is tractor or hydraulic pack why not just buy a cheap hydraulic splitter and a saw horse? 15 cube would be fairly leisurely over a few weekends.
Or even a powered splitter with good capacity,  I do anything from 25 to 35 cube with chainsaw and tractor with log splitter any odd couple of hours here and there get a bit done.
As said, if it's value for money you're better off hiring a processor. If you enjoy cutting your own wood it will make things much faster on straight logs but you're probably better off investing in a nice axe or hydraulic splitter as opposed to spending a few thousand on a processor.
