Here is a pic - not a great one sorry.  Lovely timber for things like craft work, mirror frames etc.  Not everyone's cup of tea, but if I were nearer to you Saul (and had any cash) I would offer to buy the whole tree off you (milled).
That will more than likely be rotten/hollow it dont look a big tree ! but it looks in bad shape!! there probably just cankers, we did one in late oct and i was going to ring you but tree was not worth the effort to even try and move so it stayed where it fell,
You're probably right.
(As per usual[emoji6])
But with the wonders of two mix epoxy resin table makers...[emoji7][emoji848]
If it can be milled in one piece, it's probably worth it.
[emoji106][emoji106][emoji106]
Hi Squardey, I have quite a few fairly big Ash trees that are cankered , on the small Est I look after I could easily take one or 2 out and mill some if you want to buy some PM if you are interested
Cheers Mark
Cheers Mark
Thanks Mark, I will send a PM.
Get them stickered or they will get surface mold and staining.
[emoji106]
Was hopingthey might become splated but probably not. Need to cover them from the sunlight and paint the ends as well
22 hours ago, Rough Hewn said:
Looked at a job today in a small woodland.
Anyone ever milled burred ash? Or is it cankered?
I've got about 20 Sweet Chestnuts that look similar to that in my woodland.
I felled and milled a couple last year, fantastic grain.
Question time ?
I have these logs that I'll be milling over the wknd
The one at the back on the right is cherry
4 other big logs are beech and little one at the front is obviously oak
Question is what's the best thickness to do them to keep the wood as stable as possible during drying, I'm thinking 40/50mm? They'll most likely be used for a bbq area or that sort of idea, so most likely external application
Also, does anyone ever spray their slabs with woodworm preservative just to do all they can to get the little shits out?
Thanks again ?
