On 10/01/2020 at 17:12, Khriss said:
Odd innit. Its obvs to lube a bearing an under huge loads like milling, you would think its so- an then you find different!  Never seems to matter in my run of bars, k
I think what happens is grit mixes with the grease and causes the bearing to seize.
On 06/01/2020 at 10:43, Forest2Furniture said:
Only ever had that problem once, told RobD and he sent new parts straight away.
Instructions when new was to lubricate it but that was the problem, grit from the tree stuck in the oil and jammed it up. Since replacing the nose sprocket I've not bothered to oil and have had no problems now for over 5 years.
I'm in this camp .
12 hours ago, arbwork said:
interesting Brown Oak today , usual nails 9_9 a little rot but mainly lovely deep brown colour (not shown well in the photos)1641379410_mobilesawmillingoak1.thumb.jpg.07b3d79aac0a5e0efee465ea86e8cae1.jpg saw dust looks almost like paprika :001_smile:
Hey arbwork, it looks like you’ve got the miser cutting well ! Couldn’t help but notice your using a metal detector in one of the photos - Is it worth while or do you just detect the mill the whole time ! Wondering about getting one - do you know what brand it is ?
Nice Brown Oak ,I have just made a big dining table and 2 benches out of brown oak , but I can’t post any pictures of it yet as it’s for a fellow arbtalker that hasn’t seen it yet and I don’t want to spoil the surprise ,brown oak is bloody expensive as I just found out but is nice to work and looks ace.
metal detector are worth the time, any help in preventing sawing metal, yes you have to get used to signal from saw bench, have to sweep over each cut to get best result can be time consuming, 5 nails in last trunk cut!
''brown oak is bloody expensive ''   can I ask how much per cu ft ?  thanks
