15 minutes ago, Big Beech said:
Yes,much better.
The winch has been on for a while, just forgot to take the string with me.
Just need to carefully listen to the pitch of the engine to make sure your at optimum revs.
Never get that issue with the 661 its poetry in motion handled right 😉
Moved some lumps of Oak for the last time today, only been meaning to mill then for about 5 years. So made a plan to make a start today and was very happy with first cut.
  • Like 9
  • 3 weeks later...
Not done much milling for a few years, and only ever as a hobby for my own use. So hopefully the pro’s won’t roll their eyes too much…. This wasn’t a money making venture.
I was offered some of this beech butt earlier this year by my brother in law who’d had it delivered to his house already cut into three sections. He needed help cutting it up for firewood. He mentioned there was some rot, so I immediately thought, spalted beech, maybe mill it?
Today’s (half day) milling was the top section. The bottom 8 feet was so rotten it was almost possible to crawl inside the hollow trunk! We’d cut it into rings for firewood a few weeks ago. But the top section, about 5 ½ feet long showed more promise. The rot was coming down from the top, not up from below. My mill is the 24” Alaskan, a bit small for milling a 3 foot diameter butt! However, the odd shape, meant that with minimal freehand trimming, the mill fitted fine on the top part. The bottom half was then freehand sawn down the middle, split apart, and milling continued down the right hand side below what had already been completed, to create matched slabs 3 inches and 2 ½ inches thick, about 20 inches wide. I suspect they might distort a bit and perhaps split as it’s at the transition between the 1st and 2nd lengths with grain running in different directions, but pretty sure there will be some worth keeping and at those thicknesses, there should be plenty to plane off to flatten them.
Some nice looking bookmatched slabs, even allowing for the rot at the top end that will need to be cut off. Decided to let my nephew keep most of the slabs but I’ve kept a 20 inch wide by 4 ½ inch slab which might become large bowl blanks one day. And there was lots of firewood.
Was good to be out with the mill today. Reminded me how much fun it is opening up a lump of wood, wondering what will be inside, the delight when it’s something special, then dreaming about what could be made with it…….
Andrew
  • Like 10
1 hour ago, Big Beech said:
No milling, but some nice Burr field maple logs from a customers garden.
24" diameter x 3m long x 3.
May leave one to splat for a few years.
Funnily enough I've just been contacted about milling some Spalted Burr (maybe burr) Maple. They're not planning on going ahead with it due to the cost and no-where to store the Slabs. About 36" diameter but they cut the log in two so only a 2m and 1.7m length. Ive suggested I come mill it and leave them a slab. They're planning on cutting it up for firewood though.
I wonder if its worth the day out milling?
Just a stab on my part but I would say yes from the pics . Easy for me to say sitting here I know .
Edited by Stubby
