Sorry for slight thread derail, I have searched on here but getting mixed messages. I have bought a sawmill powered by a chainsaw, and will be running either my 395xp or 3120xp as the powerhead, only a 36" cut at the moment. The guy I bought it from ran an 880, he said always on 25/1 mix or it will lean seize. I have never run my saws on that strong a mix, @spudulike would you or anyone else be able to give me a more definitive answer?
Thanks.
Alf
Sorry for slight thread derail, I have searched on here but getting mixed messages. I have bought a sawmill powered by a chainsaw, and will be running either my 395xp or 3120xp as the powerhead, only a 36" cut at the moment. The guy I bought it from ran an 880, he said always on 25/1 mix or it will lean seize. I have never run my saws on that strong a mix, [mention=30144]spudulike[/mention] would you or anyone else be able to give me a more definitive answer?
Thanks.
Alf
I've always used 50:1 of good quality stroke oil (Jaso fd) never had a milling saw seize. They are perhaps tuned slightly rich I.e not right up to absolute max rpm out of the cut. A pal with a 3120 runs 40:1 in his. Also not had any bother.
You will probably get a whole range of answers, I would er slightly on the side of caution as whatever saw your going to use will be run flat out for a extended period of time. But if your saws are issue free, tuned properly and you use a good 2 stroke oil you'll be reet
Thanks.
Alf
Standard 50:1 never had a problem.
Moved over to alkylate pre mixed a while back no problems.
Only ever seen one engine go, and that was a suspected air leak.
I rev the engine after each cut and let it tick over with a bit of revs to cool the engine and oil the chain.
About 30 seconds.
[emoji106][emoji106][emoji106]
On 14/03/2019 at 18:14, Erik said:
The fact that their wood is extremely brittle,  and hard to work with was probably what saved them from extinction.
I read something years ago saying that much of the timber from these had so many shakes from felling that it ended up as shingles. I remember a photo of a trench filled with branches that they'd felled a tree into, in an attempt to prevent shakes - extraordinary lengths to achieve usable timber!
Hi, I have quite a bit of cherry to mill for myself, about 18-24 inch wide by about 4 ft long. However the few boards I have already cut are splitting and twisting like heĺl, this is despite me pva ing the ends and boards being laid flat on stickers. Also I have some small 4 inch diameter by 6 inch pieces that I'm hoping to use on my laith, however these are also splitting badly.
So just what is the best way of drying cherry ?
Cheers
H.
Thank you Bill and Saul, thats what I was looking for.
Cheers
H.
yes there is.
reeeaaaallllyyy slooowlllyy.
end seal and keeping it out of the elements so it dries at a slower rate and hope like hell it works...
All the above is sound advice to follow.
However, if the tree is vertical and balanced...
This is my coffee table,
I felled the tree in August last year,
Milled up within a couple of weeks.
Leant against a wall for a fortnight,
Before being knocked into table shape in a morning.
No sanding or oiling, raw.
Then left in front of a south facing window, close to a radiator.
Probably September.
It has warped and cracked but only slightly. (To my great surprise)
[emoji848][emoji106][emoji106][emoji106]
Got a bit more of the elm today, only coffee table size.
Borrowing a mill from a mate, so should get them milled on Wednesday.
