That was the day I was having a mare  with the new set up and chains Saul, I’d given up at that point but seeing those come up like that perked me up a bit. Any recommendations for drying/avoiding splitting (90mm thick)
Slow drying possibly.
Elm is very cohesive.
But I’d imagine most will split.
Resin types like the splits though.
[emoji106]
Only way to stop those rounds splitting is to seal them both sides  with at least 2/3 coats of stuff and dry them slowly
Edited by topchippyles
1 minute ago, topchippyles said:
Only way to stop those rounds splitting is to seal them both sides  with at least 2/3 coats of stuff and dry slow
What stuff would you use to seal them with ??
A couple of methods which I've not tried are drilling a 'largish' hole to remove the pith, or soaking the disk in PEG (polyethelyne glycol). Not sure what size of hole would be needed, I'd guess 25 to 50mm diameter, but maybe someone could advise on this? But a patch in the middle might not look too good.
What I did about 20 years ago was use an ovalish piece of wood which had been cut at an angle instead of straight across the butt. I bought the air dried slab from Boddy's of Boroughbridge (no longer in business unfortunately) and leant it against the wall on our landing for a few months to acclimatise to the centrally heated house. It distorted quite a bit, but it didn't crack from the centre to the edge. So, that method of milling could be experimented with. The attached notes explain a bit about the table I made which  which still looks as good as the day it was finished.
Andrew
Andrew
That’s bloody lovely 👍
Andrew
Very interesting post, and a fantastic looking table, thanks.
A friend of mine learned from Tim Stead after leaving college, he was such a skilled and knowledgeable man. I often pass his memorial in the community woodland he established near his home
Spalted beech anyone?
Back on to milling large beech. 9’ long x 2.5’ wide. Doing some in 2” and thicker.
Have a lot to mill. Anyone got a view as to best thickness of planks?
IMG_3971.thumb.jpg.a42d2605164ef4f224edb61167ad949f.jpgIMG_3965.thumb.jpg.f842629a6e6fa640f2d4bab4a7d9ba5f.jpgIMG_3968.thumb.jpg.a35154e1ea9ba5bf920fc405bca58d85.jpg
Nice boards[emoji108]
I cut nearly everything at 55mm these days.
Gives a bit of room for planing/routing.
[emoji106]
