Hi gents
I obviously know why you should use proper chain oil, however i was talking to someone that uses pretty much what ever he can get his hands on. so car oil, cooking oil and even 2-stroke. When I questioned about its effectiveness he said as long as it lubricates the chain then it's fine.
Me not having a great deal of experience in the industry I think this is probably a cowboy method for using a saw (and damaging to both saw and tree) however is he in some way right or at least in an emergency you could get away with it? I would love to hear your thoughts.
I should mention the guy was quite skilled and has been doing tree work for a number of years, however the company he works for is somewhat shocking, I'm not going to name names though.
Edited by Boggle4137
Just now, Boggle4137 said:
By damaging I meant something along the lines of say lasting damage or poisoning of the tree if it isn't being cut down.
I knew that . I was just being a knob ! ? Some sensitive areas , like a SSSI for instance or near a water course might require bio oil only for the environment .
I use bio chain oil from Clark Forest. Mainly rapeseed. If saw is left for weeks/months the chain tends to sieze so takes a bit of loosening. Ethanol is great for getting them unstuck.
Bio maybe good for the environment, but is a nightmare to get off the saw, it turns to what i can only describe as chewing gum, leave it in an unused saw and the pump seizes and the pick up and delivery pipes bung up, i hate the stuff. whatever happened to Oregon green leaf, looked like milk!
Bio oil can't be pure rape oil then.  I've been using rape oil for years, including in the 064 which probably only comes out to play once a month or so, and never had any caking, blocking, gumming issues.
