2wd Forest Tractor - Opinions
AndyO
Come on Matty pics of the 6400! also is that a sanderson t2?
Not sure swinny it’s been a long time since I used the Sanderson... it’s belonged to an estate I worked on... was a good tool until you accidentally selected crab steer and it would get stuck in that gear!
Tractor porn awesomeness-keep it up!!!
4x4 would definitely be my first choice but they are either over budget or have had the daylights kicked out of them. Would 2wd do till budget allows for a 4wd...plus when you’ve got a big snig on what difference do the front wheels make when they are up in the air???
1 hour ago, spuddog0507 said:
This is what we hired in in the spring of 2015 when for use it was either rain or snow every day ground was saturated and the job was infected larch , fell and skid out, machine Not 2wd or 4wd but a fantastic bit of kit,
Something I just love about these crawler tractors,
Do u think these crawler tractors are better than the 4wd alternatives for the more modern wetter climates?
How do they cope going up steep hills? I now the tracks are a bit more aggresive than digger tracks bit rubber tracked diggers do struggle in greasy conditions
Some of them are not that expensive
