7 hours ago, donnk said:
if the pipe has water in it it cant be crushed.
You cannot compress a liquid. basic physics.
T'was only a tree surgeon telling me where I'm going wrong, now it's a machine driver/ground worker. I'm going to have to up my game...
Edited by eggsarascal
You cant compress a liquid..... maybe not, but you can compress the pipe which will effectively split the liquid in two stopping any flow. ?‍♂️ basic physics.
Just to be pedantic, all liquids are compressible to some degree - just not a lot. Except silicone break fluid which is compressible a lot.
not really, their state of compression can be effected in a very minor way by changing temperature. Not by compression!
How about I stand on a hose pipe while you look into the end of it to see what the problem is?
Of course you can crush a pipe that has water in it!?
I should know, I'm an expert on plumbertalk.com.
No really, liquids can be mechanically compressed. Just not by a lot. I googled it
Water pressure has dropped off to house in the last couple of years, have checked for leak found a couple of small leaks between mine and house up the road this is all on private property   but still bad.
Pipe travels by a oak tree so has anyone now if root can squash pipe to cause restricted flow.
You dug a hole yet woody paul?
Strictly speaking, yea a radial root expansion could crush a plastic waterpipe-in practise, the soil would give around the pipe, and it would get  pushed away. K
