2 hours ago, difflock said:
No kindling needed, a few handfuls of scrunched up newspaper and a few casually selected likely looking sticks, picked from those brought in for burning, i.e. 1/2 rotten, or thin section, or splintery or a hydraulic wedge split & "ruffelled" knotty Lodgepole pine.
A few minutes later with the door "snibbed" open, a roaring inferno.
Since there was a bit of discussion about hoth air igniters some while back I bought a £17.50 Einhell (matches the saw I was given) hot air gun. I load the fire and point the gun through the air inlet, never takes more than a minute as long as there is a bit of split pallet wood in the line of fire.
Hush you!
I still like playing with matches.
But
Back in our barbacuing days I used a cheap hair dryer to accelerate the ignition of the charcoal.
And I always fancied a MAPP blowtorch for that application.
Some of better gasifying logwood boilers, uses a hot air gun for ignition, however one of the best designed (with respect to easy cleaned from the front flue tubes, and I have foregotten the brand, DOH!) simply uses an inbuilt  propane blowtorch, which is pure simple pragmatic genius.
mth
Edited by difflock
3 minutes ago, flatyre said:
How well does Eucalyptus burn and is it hard or soft wood? Have loads of it in the shed but made the mistake of not splitting it immediately, like concrete:|
It's a hardwood and burns brilliantly but as you have found out, it's a pain to split when dry
Just now, flatyre said:
have been told its not safe to burn on open fires, urban myth?
Maybe it spits a bit like chestnut. Use a fireguard
Not a myth  . Stove only  . Love it . Makes charcoal in the morning .
On 1/26/2018 at 09:09, Lucan said:
But are the costs per kw the same?
Softwood has around 75% the energy of hardwood per volume, which means from the customer's side they would be looking at 70-75% to make switching interesting. However you often see softwood only around 10-15% cheaper so is it any wonder the slow demand. I guess that is because although softwood is cheaper to produce that often doesn't match a final 25% cost reduction including delivery?
have a look at this http://www.fao.org/3/a-i4441e.pdf
i had a discussion with a stove seller who tells all his customers never to burn softwood, which really got my goat as where we are there is no hardwood and i only supply kiln dried softwood
Maybe a free bag of softwood for this stove seller would be a good investment for you? It might make him reconsider the advice he gives...
