hey
was in a discussion with a colleague to day during felling and she never heard of this. now i call bunny ear but it could be wrong name for so what do you call the small cuts you put in below the hinge/ gob to stop the bark tearing down?
skyview
  • Replies 22
The 2 cuts i put at either side below hinge i thought were called sap wood cuts and i only usually put them in at spring time
Stops the butt wood splitting right up the stem
I've always heard them referred to as ears. Normally done on "snappy" species with a tendency to tear. Willow, popular etc. Good on small diameter cord wood or if felling a stand which is slightly too big for the bar.
Ears or wing cuts, they primarily used when topping something out that you are roped around i.e. The stem, to prevent it splitting and opening up thereby squashing you against the stem.
Sent from my iPad using Arbtalk
Sapwood cuts here.
Usually use them on the ground if the stump is staying, especially if it's being a left a little higher, especially on willow or connies if we're pulling them.
Nowt worse than unsightly bark tears on Mrs. Miggins new planter stand.
