On the occasional fencing job I've had (funnily enough I never get much word of mouth fencing work!)
I've used the petrol auger on wheels like the one pictured, only it was direct drive rather than hydraulic, brilliant bit of kit, only issue is that when it gets itself under a tree root you have to disconnect the auger and reverse it by hand to extract it.
  • Replies 27
Whats benefits? Looks less to man handle
You do not go round in circles when it hits something hard and it has a pendulum affected with the weight of the motor on the end
could of done with one these a couple of months back, then again maybe not!!..
I did a post an rail fence for one of my customers, not so much a case of digging out as mining out a hole every half hr..
200 posts? I'd be getting a digger (any size that will fit) with an auger on it, you will have them all drilled out in a day if you have them all premarked beforehand.
I can't stand those handheld post borers- dreadful things and I'd sooner use a good grafting space and shoveholers given the choice.
Digger and auger every time if access permits
This. If you can get a really big auger all the better.
Experience says :thumbup1:
No access! All hedging & trees are out can only just get grinder in, 2 foot narrow ginnell down side of house then around 20 steps down to courtyard and a few back up! Will be a killer!!!
What are these like with roots? On a job at the mo we've taken out a manky conifer hedge stumps out and 8 panels going in. Did 2 holes before leaving today 6 to go tomorrow. Bound to hit a few missed roots though. Will these machines just jam on the roots/stones and hurt your wrist or power through?
Sent from my SM-G930F using Arbtalk mobile app
One man augers are a waste of time round here. Even the two man ones are crap. Hit anything like a flint and it will stop dead, or send you flying round.
best one is the one on wheels made by digga, its hydraulic, so has a reverse if it jams. It also has teeth that will grind through flint and the whole thing comes apart and can be put in the boot of a car
