Can't issue pre-worn boots/ trousers / helmet = infection nightmare
:confused1::confused1:
As long as its functional and washed its fine, especially for a newbie
A hygiene kit is all you need for anything that wont go in the washer
From the HSE website, there's also an expanded Q&A PDF - looks like theres nothing in there to mandate new PPE for new employees. As long as its "maintained in good condition" its fine...
Do employers have to provide personal protective equipment (PPE)?
The relevant regulations are the Personal Protective Equipment at Work Regulations 1992.
Regulation 4 states:
Every employer shall ensure that suitable personal protective equipment is provided to his employees who may be exposed to a risk to their health or safety while at work except where and to the extent that such risk has been adequately controlled by other means which are equally or more effective.
The accompanying guidance states:
Employers should, therefore, provide appropriate personal protective equipment (PPE) and training in its usage to their employees wherever there is a risk to health and safety that cannot be adequately controlled by other means.
In order to provide PPE for their employees, employers must do more than simply have the equipment on the premises. The employees must have the equipment readily available, or at the very least have clear instructions on where they can obtain it.
By virtue of Section 9 of the Health and Safety at Work etc Act 1974, no charge can be made to the worker for the provision of PPE which is used only at work. Section 9 of the Health and Safety at Work etc. Act 1974 states: "No employer shall levy or permit to be levied on any employee of his any charge in respect of anything done or provided in pursuance of any specific requirement of the relevant statutory provisions". Section 9 applies to these Regulations because they impose a 'specific requirement' - i.e. to provide PPE.
Personal protective equipment (PPE) at work
A brief guide
This is a web-friendly version of leaflet INDG174(rev2), published 06/13
Introduction
This leaflet describes what you, as an employer, may need to do to protect your employees from the risk of injury in the workplace. It will also be useful to employees and their representatives.
Employers have duties concerning the provision and use of personal protective equipment (PPE) at work and the leaflet explains what you need to do to meet the requirements of the Personal Protective Equipment at Work Regulations 1992 (as amended).
What is PPE?
PPE is equipment that will protect the user against health or safety risks at work. It can include items such as safety helmets and hard hats, gloves, eye protection, high-visibility clothing, safety footwear and safety harnesses.
Hearing protection and respiratory protective equipment provided for most work situations are not covered by these Regulations because there are other more specific regulations that apply to them. However, these items need to be compatible with any other PPE provided.
Cycle helmets or crash helmets worn by employees on the roads are not covered by the Regulations. Motorcycle helmets are legally required under road traffic legislation.
The Employment Act 1989 gives an exemption for turban-wearing Sikhs working on construction sites from the need to wear head protection.
What do the Regulations require?
PPE should be used as a last resort. Wherever there are risks to health and safety that cannot be adequately controlled in other ways, the Personal Protective Equipment at Work Regulations 1992 require PPE to be supplied.
The Regulations also require that PPE is:
■ properly assessed before use to make sure it is fit for purpose;
■ maintained and stored properly;
■ provided with instructions on how to use it safely;
■ used correctly by employees.
Page 1 of 6
Assessing suitable PPE
To make sure the right type of PPE is chosen, consider the different hazards in the workplace and identify the PPE that will provide adequate protection against them; this may be different for each job.
Ask your supplier for advice on the types of PPE available and their suitability for different tasks. In some cases, you may need to get advice from specialists or from the PPE manufacturer.
Another useful source of information is the British Safety Industry Federation (www. bsif.co.uk).
Consider the following when assessing suitability:
■ Does the PPE protect the wearer from the risks and take account of the environmental conditions where the task is taking place? For example eye protection designed to protect against agricultural pesticides may not offer adequate protection when using an angle grinder to cut steel or stone.
■ Does using PPE increase the overall level of risk or add new risks, eg by making communication more difficult?
■ Can it be adjusted to fit the wearer correctly?
■ What are the needs of the job and the demands it places on the wearer? For
example, the length of time the PPE needs to be worn, the physical effort
required to do the job or the requirements for visibility and communication.
■ If someone wears more than one item of PPE, are they compatible? For
example does using a respirator make it difficult to fit eye protection properly?
Selection and use
When selecting PPE:
■ choose good quality products which are CE marked in accordance with the Personal Protective Equipment Regulations 2002 – suppliers can advise you;
■ choose equipment that suits the wearer – consider the size, fit and weight; you may need to consider the health of the wearer, eg if equipment is very heavy, or wearers have pre-existing health issues, standard PPE may not be suitable;
■ let users help choose it, they will be more likely to use it. Using and distributing PPE to your employers:
■ instruct and train people how to use it;
■ tell them why it is needed, when to use it and what its limitations are;
■ never allow exemptions for those jobs that ‘only take a few minutes’;
■ if something changes on the job, check the PPE is still appropriate – speak with
your supplier, explaining the job to them;
■ if in doubt, seek further advice from a specialist adviser.
Personal protective equipment (PPE) at work Page 2 of 6
Health and Safety Executive
The hazards and types of PPE
Eyes
Hazards: Chemical or metal splash, dust, projectiles, gas and vapour, radiation. Options: Safety spectacles, goggles, face-shields, visors.
Note: Make sure the eye protection has the right combination of impact/dust/ splash/molten metal eye protection for the task and fits the user properly.
Head
Hazards: Impact from falling or flying objects, risk of head bumping, hair entanglement.
Options: A range of helmets, hard hats and bump caps.
Note: Some safety helmets incorporate or can be fitted with specially-designed eye or hearing protection. Don’t forget neck protection, eg scarves for use during welding. Do not use head protection if it is damaged – replace it.
Breathing
Hazards: Dust, vapour, gas, oxygen-deficient atmospheres.
Options: Disposable filtering face-piece or respirator, half- or full-face respirators, air-
fed helmets, breathing apparatus.
Note: The right type of respirator filter must be used as each is effective for only a limited range of substances. Where there is a shortage of oxygen or any danger of losing consciousness due to exposure to high levels of harmful fumes, only use breathing apparatus – never use a filtering cartridge. Filters only have a limited life; when replacing them or any other part, check with the manufacturer’s guidance and ensure the correct replacement part is used. If you are using respiratory protective equipment, look at HSE’s publication Respiratory protective equipment at work: A practical guide (see ‘Further reading’).
Protecting the body
Hazards: Temperature extremes, adverse weather, chemical or metal splash, spray from pressure leaks or spray guns, impact or penetration, contaminated dust, excessive wear or entanglement of own clothing.
Options: Conventional or disposable overalls, boiler suits, specialist protective clothing, eg chain-mail aprons, high-visibility clothing.
Note: The choice of materials includes flame-retardant, anti-static, chain mail, chemically impermeable, and high-visibility. Don’t forget other protection, like safety harnesses or life jackets.
Personal protective equipment (PPE) at work Page 3 of 6
Hands and arms
Hazards: abrasion, temperature extremes, cuts and punctures, impact, chemicals, electric shock, skin infection, disease or contamination.
Options: Gloves, gauntlets, mitts, wrist-cuffs, armlets.
Note: Avoid gloves when operating machines such as bench drills where the gloves could get caught. Some materials are quickly penetrated by chemicals so be careful when you are selecting them, see HSE’s skin at work website (http://www.hse.gov.uk/skin).
Barrier creams are unreliable and are no substitute for proper PPE. Wearing gloves for long periods can make the skin hot and sweaty, leading to skin problems; using separate cotton inner gloves can help prevent this. Be aware that some people may be allergic to materials used in gloves, eg latex.
Feet and legs
Hazards: Wet, electrostatic build-up, slipping, cuts and punctures, falling objects, metal and chemical splash, abrasion.
Options: Safety boots and shoes with protective toe caps and penetration-resistant mid-sole, gaiters, leggings, spats.
Note: Footwear can have a variety of sole patterns and materials to help prevent slips in different conditions, including oil or chemical-resistant soles. It can also be anti-static, electrically conductive or thermally insulating. It is important that the appropriate footwear is selected for the risks identified.
Training
■ Make sure anyone using PPE is aware of why it is needed, when to use, repair or replace it, how to report it if there is a fault and its limitations.
■ Train and instruct people how to use PPE properly and make sure they are doing this. Include managers and supervisors in the training, they may not need to use the equipment personally, but they do need to ensure their staff are using it correctly.
■ It is important that users wear PPE all the time they are exposed to the risk. Never allow exemptions for those jobs which take ‘just a few minutes’.
■ Check regularly that PPE is being used and investigate incidents where it is not. Safety signs can be useful reminders to wear PPE, make sure that staff understand these signs, what they mean and where they can get equipment, eg for visitors or contractors.
Maintenance
Make sure:
■ equipment is well looked after and properly stored when it is not being used, eg in a dry, clean cupboard, or for smaller items in a box or case;
■ equipment is kept clean and in good repair – follow the manufacturer’s maintenance schedule (including recommended replacement periods and shelf lives);
■ simple maintenance can be carried out by the trained wearer, but more intricate repairs should only be done by specialists;
Personal protective equipment (PPE) at work Page 4 of 6
■ replacement parts match the original, eg respirator filters;
■ you identify who is responsible for maintenance and how to do it;
■ employees make proper use of PPE and report its loss or destruction or any
fault in it.
Make sure suitable replacement PPE is always readily available. It may be useful to have a supply of disposable PPE, eg for visitors who need protective clothing.
CE marking
Ensure any PPE you buy is ‘CE’ marked and complies with the requirements of the Personal Protective Equipment Regulations 2002. The CE marking signifies that the PPE satisfies certain basic safety requirements and in some cases will have been tested and certified by an independent body.
Other regulations
The PPE at Work Regulations do not apply where the following five sets of regulations require the provision and use of PPE against these hazards. For example, gloves used to prevent dangerous chemicals penetrating the skin would be covered by the Control of Substances Hazardous to Health Regulations 2002 (as amended). The Regulations are:
■ The Control of Lead at Work Regulations 2002.
■ The Ionising Radiations Regulations 1999.
■ The Control of Asbestos Regulations 2012.
■ The Control of Substances Hazardous to Health
■ The Control of Noise at Work Regulations 2005.
Key points to remember
Are there ways other than using PPE to adequately control the risk, eg by using engineering controls? If not, check that:
■ suitable PPE is provided;
■ it offers adequate protection for its intended use;
■ those using it are adequately trained in its safe use;
■ it is properly maintained and any defects are reported;
■ it is returned to its proper storage after use.
Can I charge for providing PPE?
An employer cannot ask for money from an employee for PPE, whether it is returnable or not. This includes agency workers, if they are legally regarded as your employees. If employment has been terminated and the employee keeps the PPE without the employer’s permission, then, as long as it has been made clear in the contract of employment, the employer may be able to deduct the cost of the replacement from any wages owed.
Personal protective equipment (PPE) at work Page 5 of 6
Further reading
Hard hats: What you need to know as a busy builder Construction Information Sheet CIS70 HSE Books 2013 http://www.hse.gov.uk/pubns/cis70.pdf
Hazardous substances at work: A brief guide to COSHH Leaflet INDG136(rev5) HSE Books 2012 http://www.hse.gov.uk/pubns/indg136.htm
Lead and you Leaflet INDG305(rev2) HSE Books 2012 http://www.hse.gov.uk/pubns/indg305.htm
Noise at work: A brief guide to controlling the risks Leaflet INDG362(rev2) HSE Books 2012 http://www.hse.gov.uk/pubns/indg362.htm
Personal Protective Equipment at Work (Second edition). Personal Protective Equipment at Work Regulations 1992 (as amended). Guidance on Regulations L25 (Second edition) HSE Books 2005 ISBN 978 0 7176 6139 8 http://www.hse.gov.uk/pubns/books/l25.htm
Respiratory protective equipment at work: A practical guide HSG53 (Third edition) HSE Books 2005 ISBN 978 0 7176 2904 6 http://www.hse.gov.uk/pubns/books/hsg53.htm
Selecting protective gloves for work with chemicals: Guidance for employers and health and safety specialists Leaflet INDG330 HSE Books 2000 http://www.hse.gov.uk/pubns/indg330.htm
Further information
For information about health and safety, or to report inconsistencies or inaccuracies in this guidance, visit http://www.hse.gov.uk. You can view HSE guidance online and order priced publications from the website. HSE priced publications are also available from bookshops.
This guidance is issued by the Health and Safety Executive. Following the guidance is not compulsory, unless specifically stated, and you are free to take other action. But if you do follow the guidance you will normally be doing enough to comply with the law. Health and safety inspectors seek to secure compliance with the law and may refer to this guidance.
This leaflet is available at http://www.hse.gov.uk/pubns/indg174.htm.
© Crown copyright If you wish to reuse this information visit http://www.hse.gov.uk/copyright.htm for details. First published 06/13.
next time buy PPE from a company that will let you return it if it doesn't fit (or your apprentice quits)
And how does that work if the apprentice quite 3 months in, who is going to take back used boots and trousers! ????
Sent from my SM-N910F using Arbtalk mobile app
Hi since I have to hire my PPE for all my tickets. I've decided to buy my PPE kit for my tickets I hope to work for a company and use my kit until I assume week or month in hand is done and a permanent job is offered, after that I'd let the new company provide my PPE and my kit can go back home
Cheers
The previous companies I have worked for I have always brought in my own kit and had it replaced by the company when items get worn out.
If it's a Newby then surely as said you wouldn't have them using a saw so just some general steel toe boots and a lid will do fine. If you can see they are going to be happy with the work they think about supplying them with more expensive kit.
As for not being able to reuse nearly new kit that's just ridiculous. When they ban on about waste but they want you to fork out for new trousers even though there are a perfectly adequate pair already. I can't image anyone kicking up a fuss about some trousers that have only been used a handful of times. If they do just said your more likely to get a disease from the amount of dog crap in some of these customers gardens :-/.
I can just see the job advert. Ground man needed. Must be six foot tall with a 34 inch waist and size ten feet so that the ppe I've got fits you.:biggrin:
:laugh1: I was thinking the same.
Surly there is no issue in using second hand ppe if it has a paper trail and in good condition? When in college there was a lot of using xxxxx hand ppe.
I would buy minimal cheap but relevant ppe and upgrade as and when for new starts.
