  • Replies 31
Are we talking 'cut throat' type razors / shaving here...? :001_huh:
Dr John's blade would trim a beard nicely!
I'm goin' straight down to dat barber supply shop, get me a pearl handle, double edge, hollow ground, super blue blade, adjustable, stainless steel, honed edge, both blades on the same side so when I cut you once, you gonna bleed twice, goin' an' comin'. An' if you don' believe me, shake yo' head; it'll be singin' "I ain't got no body."
about 3 minutes into "How come my Dog don't bark when you come round"
[ame]
[/ame]
I use a standard Gillette cartridge razor.
Until last year I would use them about three times before they became blunt and I got a new one. Then I found out they weren't actually blunt but dirty (smeared with soap). If you get a cloth (like an old pair of jeans) you can rub the razor over the cloth and the razor is sharp again. I must get about 50 shaves from each razor blade now. It's a fair saving each year.
Not shaving is even cheaper😁😁
I got a "Shavette" which has disposable razor blades and requires none of the maintenance of a traditional straight razor, good bit of kit.
sounds like a lady razor to me, is it pink:confused1:
