14 hours ago, josharb87 said:
Anyway, going off track, There was no way that tree, with that side wind and that pulling angle was ever going to land on the grass :lol:
Assuming the tree was sound, Do you think a decent hinge would have broken early with that side wind assuming the gob was set correctly?
The sound profile of the cutter's saw didn't instil a great deal of confidence that he was a competent feller...  Which might leave open the question of face cut and back cut accuracy and hinge integrity?  Just thinking out loud....
Yup, I listened carefully to the saw in the film and there was a Definately point where he stopped, then carried on cutting, but the truck didn't  move to tension the rope. Dimension yr hinge an cut to it- possibly he thought 'just a bit more '...... K
Im rather jealous of your shiny capstan.  Is it any good for skidding?
It makes a good lowering bollard, Arcto, cos it can lift when engine engaged, but for skidding timber out, I would think a front ground anchor would need attaching. K
Whenever we tug trees over with a truck I always make sure someone reliable, and with a clear view of proceedings, stands next to the drivers open window, so that precise instructions are given on tension and when/how to move as the fell progresses. Not standing back in the road wiggling their fingers around.
My thoughts too, if you cut through the tension side of the hinge on a side leaner/wind direction it’s always going to go sideways. Even with a quick pull it’s likely to end up not going where it’s desired. Saying that I’ve felled pops with slight side leans and the whole stump has failed or one of the buttresses tears off with the hinge.
That rope went slack immediately, pointing to a hinge being cut through.
Agree though, clear communication in a tricky situation is essential (and easily organized)
