Could well be the operator is as useless as the machine/grinder, I've sharpened chains well with my £90 grinder [emoji6]
Guess who I was writing about?
How ya doin mate?
[emoji106]
I know who you were referring to (mr c) lol...  His  name is Livin up to his reputation
Anyhow I'm fine, I've been making more white lightening from my orchard,
best not hijack this thread. Otherwise, I'll get flamed. ?
On 12/21/2017 at 07:06, Rough Hewn said:
Cheap grinders are sh*t.
Plastic, wobbly useless crap.
My mate bought one £30 it was useless.
He then spent £90 on a better one.
Still useless plastic wobbly sh*t.
After seeing my mates frustration I bought a stihl HOS grinder.
It works really well.
You can always buy sh*t cheap, doesn't mean it'll work though.
Try grinding depth gauges at 0.65 mm with a machine
that wobbles 3mm each way.
I presumed the above was true but could not resist trying the Lidl one for just £20. Honestly for the money I cant fault it. Yes if your heavy handed you can balls up sharpening with it as the stops are not rock solid. If used with a light touch and a bit of care it's more than capable of quality consistent sharpening. I use it for the loose processor chains but still prefer hand sharpening a chain on a saw but for quality of cut there is not a lot in it IME
Edited by Woodworks
Might be ok for rough cross cutting, but how do you file the depth gauges?
Wouldn't work for a ripping chain as all the teeth would be different lengths.
Angles won't be really accurate either.
Good for in the woods though.
  • 8 months later...
Resurrecting an old thread I know..........................................
So of the current crop of bench sharpener options on ebay or similar can anyone advise on which are worth buying or at least which are best to avoid?
Thanks.
