Here you go, this is what they look like in the disk, even got twin lined spout with a rubber insert to help quieten down the discharge.
Poor old abandoned Kwikchip
Edited by swinny
I know, it's been left to the nettles for a bigger machine but it was rediculous putting 150hp through a 6" machine.
It would make a brilliant front mount for a smaller mog as can be close coupled and take the reversing box off and spins the correct way as standard.
I’d imagine they wear in the v - can you swap the blades to double their use before sharpening (ie are all 4 blades the same)?
No, outer ones are longer than the inners, tending to find the damage is more on the outer edges than in the middle of the v
  • 3 months later...
