Are there filters or bits to grease under that plate. If so get the plasma out and cut a few holes out so you can work on them without having to drop the whole plate.
If your going to be doing a lot of brash mat driving i'd put a bit of plate over that oil filter too.
Yes there are a few bits under there, but there are flush fitting removable Windows where needed and it's a doddle to get to everything. Been giving it a good test on a steep but of chestnut coppice for the last few weeks where you really don't have many line choice options, and it's holding up very well!
  • 3 weeks later...
The massy and botex combo out in the woods earning a crust for a few days, we recon about 300ton of mostly sycamore thinnings to extract, 4m stuff is lovely but the 2.5 m stuff we cut early on in the job has been a pain today as hard to get two bays on, going to need some heat on the bolts to help loosen them so I can shove the back bunch out a bit to give a little more room, Mondays problem now!
That's a smart rig John :thumbup1:
Thanks chris, very pleased with it, got it lengthened out a bit so can now get two lots of 2.5 m on on the flatter ground, just got to remember to put the legs down now as spent so long on roofmounts I might have forgotten a time or two. 😜
Tidy machine in on same site putting up the new poles last week, hardly left a mark even on the wettest bit of the woods.
is the 399,turbod
