I was advised recently to only use Husky 2 Stroke Oil in Husky saws as they run hotter than Stihl and the oil can cope. (this was from a very reputable local chainsaw establishment)
Interestingly, one of the chaps I grind stumps for had a brand new Husky which seized after only a year. He'd been running it on Stihl Oil.
Has anyone else had a similar experience?
SG
I think its bollox . The oil has to be top quality now a days though whatever the make . I use Red Line because I can .
Do Husky's run hotter than others?
I was also advised to run my 3120 XP on a 1:32 mix by its previous owner, but I'm guessing that would have been mineral? I've been running it on 1:50 Husky oil and it seems fine. Its fitted to an Alpine Magnum so runs at full trigger most of the time as well.
It is a bit of a brute and bloody thirsty!!!!
SG
I got the short shrift from my local dealer when I asked for 4-5ltr bulk husky oil. I was sold Morris oil instead. Which he reckoned was far superior.
For some reason my face has seldom fit at local dealer and I've never had a strop with them.
In fairness the Morris hasn't let me down but I've not run the 3120xp on it yet. It's a saw you need to face with the joys of spring when you feeling invincible.
BS. Husky don't manufacture the oil themselves, neither do any of the saw co's.
Simple rule of thumb: Mineral basestock lubricant has the lowest lubricity and HTHS, earliest onset of thermal breakdown blah blah blah.
A grp3 synthetic base oil will handle higher temperatures than the above. A group 4 PAO will be even better and a group 5 POE the best.
The End.
The End.
Spot on :thumbup: of course you could always run Aspen :001_smile:
