What causes the bar to do this
Gardenmac
Sprocket nosed bars are not really up to a lot of carving with the tip, especially with the narrower guages on a little 150.
Get a solid nosed bar from RobD at sugihara, then run the chain SLIGHTLY slacker than you would on a sprocket nose. Too loose and it will slap and cause the same/similar problem. HIH
  • Replies 22
Popular Days
Thanks, recently bought an Echo off Rob , his help and advice was superb. Will be ordering a couple of bar n chains.
Don't agree with most of the comments.......it's just the price you pay for having a small tip on a bar is that that it will wear very fast.. I would say a solid tip wears even faster on a carving bar than one with a sprocket as well, I've ran both genuine Stihl carving and sprocket on 150 the solid rate of wear was frightening! So took it off , it also sapped power.
