Seen some on there but seem to be from China and saying delivery at some point next month. They on Amazon as well so prob order from there when need something else to get the order up to £20 for the free delivery
This is the set I got which seems ok. :001_smile:
Set Of 4 Carburettor Maintenance Tools Suit WALBRO ZAMA. Supplied With Case | eBay
You can download the Echo Carburettor Adjustment Table (European specification) via this link:
http://www.echo.fi/wp-content/uploads/kaasuttimensaatotaulukko.pdf
If you're starting from scratch it gives the start points etc for TAS, L & H jets.
I've only got 2 Echo machines but the carbs have needed adjusting on both from new.
Blower wouldn't accelerate beyond 5500rpm (7200rpm ideally) , and my CS-390 was very lean and was still accelerating hard at 13500 rpm (max eng rpm), off the throttle still reached 13850 rpm and obviously would have gone much higher had I hung onto the throttle.
Hope the above helps.
Good link there, :thumbup1: It seems you can download all sorts of parts lists/manual etc from almost any brands website in almost any country apart from here in the UK.
No surprise there really :thumbdown:
We do seem to lag behind. Found the new 2511 listed on the German echo site earlier already.
