Don't bother.
Wolter
why do you say that Wolter, do you reckon there is enough chain oil flying about to keep the bearing lubricated ?
On some chainsaws it is possible to lubricate the bearing from the outside, with the clutch/sprocket still in place. Use chain oil.
yes most XP huskies have a hole down thru the output shaft to lube said bearing but the 360 TES and the 2510 TES does not. I'm surprised at how tight the clutch is fitted as i failed to remove it.
I'm using chainsaws on a daily basis since 1984. I have probably bothered five times to lubricated the barings of the saws that were equipped with a designated lubrication hole. None of my saws ever broke down on a baring not being lubricated.
Wolter
Wolter
Same as that, never greased a chainsaw in 16 years of using them
Why would you want two bars and one chain? Surely one bar and two chains makes more sense? And what's the link count required on these bars? Thanks
Tiny Echo thread followers - am doing a special offer on x2 10" GB bars which run the 1/4 .043 chain and x1 chain all for £45-00+vat (free delivery).
Can buy here if it tickles your fancy!
Or get the saw as well with the x2 bars and x1 chain all for £300-00+vat.
OFFERS | Product Categories | Sugihara Guide Bars
Damn it! Now wish I hadn't bought one two weeks ago!
Hahahah!
Do you mean 2 chains and 1 bar?
Also, what are these GB bars? They don't look like the Sugihara carving bar that everyone raves about. 😐
Edited by Old Mill Tree Care
Wolter
obviously not had a stihl 261 then!!!! :001_tongue:
seems to need a new needle bearing with every other fill of fuel.:thumbdown:
