  • Replies 49
there will be some parcels coming up in next few months if thats any use to you and also some 50 foot butts
Thanks. Keep me informed please. Where abouts are they?
Very good - impressive finish off the slabbing attachment.
Got the slabber working great now. 4.8m x 1.1m ish taking 5 or 6 min per cut and leaving great finish.
I had to shim out the bar one side with some pieces of bean can lid as it was ever so slightly pitched down which was causing a washboard effect and the end of the cut pulling down 5mm deeper than the start.
I think I am going to make a second oiler though for the other end of the bar as think it is slightly under oiled on the big cuts.
That's quite a reasonable cut rate too. I think that the double ended chainsaw is a bit quicker (possibly 4 minutes for a cut like that) but you hang on for dear life. It's no fun.
Good job on aligning the bar too - that is what us bandsaw operatives have to do all the time. Even the most minute alignment variation causes a dodgy cut.
Extra oiler is certainly no bad thing.
