  • Replies 24
I tend to use brake cleaner and an old toothbrush for heavy sappy deposits or hot soapy water for normal cleaning. I also either use the compressor or a can of air duster, and a quick squirt of WD-40 for lubrication.
Willie
Mild soapy hot water, (not boiling) and a scrubbing brush. Once clean, rinse with clean water and dry. Then slight lube with something like WD40; or spray silicone and let to dry before use; or PTFE spray and let dry before use.
If after that, the krab still doesn't operate properly, it's time to recycle the krab and buy new.
Read more
