sharpening problems
simplesmasher
  • Replies 40
is the file biting into the tooth, you should feel it bite in, if you have hit a flint etc it will really harden the cutting edge and make it hard to sharpen, as others have said put a grinder on it or get your local shop to do it then use file next time you sharpen
i had a chain that a file just wouldnt touch just kept skidding about, ended up taking to the shop where they took it down on a grinder and then was fine after that...odd
not sure if thats whats happening to you?
carl
I've had the opposite, had a couple of 088 chains I didn't have the time to sharpen and dropped them in to a local work shop, when I came to resharpen them later it was like I had a knitting needle rather than a file.
Turns out they're been to hasty with the grinder and got them so hot they were too hard for the file to deal with.
On occasion the outer / upper layer of non shiny chrome extra hard layer on the surface can get bent down and the file seems to glide over it before getting a chance to bite in the area you try to sharpen , try some glasses or a magnifying glass for a close inspection at the cutters and the file ............. it is also true that good sharpening is a skill that seems to evade most pro arbs ... foresters are usually better !
