How to move a broke down tracked chipper?
simonm
Always thought how screwed i would be if the tracked chipper broke down in the middle of nowhere! how would you move it, as in could you winch it onto a trailer? would it even move or would it knacker the hydraulics?
I also use tracked chippers in places where if it broke down I'd be f##ked so if it does happen to me
I'll knock up 2 skids out of metal ( like ski,s ) then braise then together with angle iron using nuts n bolts as depending how tracks was set when it broke down use ratchet stap to secure chipper to skids then bolt a winch on front of skids ( if your chipper is not fitted with one ) then use trees, ground anchor, etc to winch it back to a pick up point
To get chipper on skids jack one side up at a time using a farm jack and slide skids under
This should work nicely and will be easy on the winch and batters I'd use the 1200lbs winch about £250 on eBay with mounting plate and power it of chipper battery 1st then booster pack
Good luck
  • Replies 68
Get an old car bonnet under the front of the tracks and tirfor it out. Buy a crate of beer and invite some mates round to take turn on the handle....
:lol:
Invite them round for a surf and turf , just dont tell them the chippers doing the surfing and they are doing the turfing:sneaky2:
Bob
