Log ID please
goat330
Hi all,
Been given some wood that was sat in a clients car park, but not sure what it is. My father reckons sweet chestnut (and he used to burn a lot of it), but I'm not convinced as a few smaller pieces @ around 20% moisture burnt without spitting at all in the burner.
It's quite light weight and was even when I originally picked it up (lower 30's %).
The most striking thing is how dark the cut ends were compared to the fresh cut/ split logs.
I know it's probably a real easy one, but I've not seen anything else standing similar in their grounds.
apologies if pic doesn't work properly, my first try!
http://thumbsnap.com/i/q3b7IRNR.jpg
Could be alder - I've only cut up freshly felled alder before and that was really wet with pink sap literally squirting out when the log grenade went in. I thought horse chestnut spit as well as sweet so shied away from that. I could be very wrong tho' !
