New timberwolf 150
jack88
  • Replies 214
From sources I've heard that the new model is now called the tw230, due to the 230x160 (or 170) feed opening, the hopper is much larger for thorn and connies. It has the same power and through-put as the tw190, all whilst being under 750kg
If its available as a Vari track and has greaseable bearings and steel fans I will be having one!
Hodge
This sounds v interesting but surely to get it under 750k it must be made of hardened cheese?
Na you have a removable fuel tank you keep in the truck, should save 30kg easy, remove the spout and put in back with chip 10kg, no spare tire 20kg, 3pot engine instead of 4pot 20-20kg, there you go just saved you 80kg without any compromise to material quality :-P
