If it's biting you, I reckon you might be using it wrong then - you can ratchet the load off of it so the line's slack before letting it freespool, or you can with the one's I've seen/used.
with tension on the ones i've used its a pretty slow and fiddley to get the the point where they can free spool. makes me feel malcordinated everytime
  • Replies 125
my metabo jigsaw since it crushed my left main index finger between the body and the 6mm hex head that holds the blade. Smashed the finger and now cant feel a thing nail is soft. I keep my left hand well out the way now did that ever hurt jelly legs aswell.
Cheap Drills
Handsaws which aren't brand new
Strimmer heads which don't release their cord
Strimmer cord which snaps before you've even cut anything
Metal felling wedges when you're using rookies
Stein Arb-trolley.
Thank you for buying it off me Normandy Lumberjack:thumbup1:
Always hated ratchet straps, they wrap themselves together before use then refuse to come undone once done up.
More recently, a Carlton 4012 grinder, pig of a machine that like our Iveco gets stuck on slight slopes on wet grass.
Ty
There is a real knack to doing it correctly once you done it right you get used to doing it. Have to agree it is fiddly though.
Sent from my iPhone using Arbtalk mobile app
You have a secondary index finger on your left hand?
He must have ties with Norfolk :laugh1: Ratchet straps are a lost cause with me, I need a knife to get them undone :(
