I've been looking into getting a big saw for a while now, something that will run a 36" bar and just wanted your opinions on whether you would get the 660 or 880?
The 880 is about £200 more than the 660 but it gives me the option of running a 48" bar in the future and it will cut faster than the 660 on the 36".
Where as the 660 will be a bit lighter and obviously £200 less.
So which would you go for?
or is there another option i havn't thought about?
  • Replies 52
HI JAMES it all down to if you cut loads of very large hard wood butts then get a 880 BUT if you only say 3/4 large butts a year then get a 660 on 3ft/30" bar it so much lighter to use all so there cheaper then £200 then a 880 get one very this month as there going up mate thanks jon :thumbup:
Good advice :thumbup1:
Same could be said of 390/395/3120.
ms660/25" bar :thumbup1:
HI JONNY thats a good size bar to run on a 660 all day long but i think the better saw to use day in day out is a 660/395 as it so much lighter to use but with 880 you could do some milling thanks jon :thumbup:
Wait and get a 661, the lower vibes and increased user comfort for me at least makes it a saw I'd happily ring up with all day. The 880 is a beast.
Or get a husky 395, not a saw I've used personally but is highly regarded.
