How longs a piece of string comes to mind etc when asking this but :
Which are the good log burner makes out there?
Obvioursly need to measure the room to find out which size to get.
What about having the log burner run the radiators?
Any help would be great. Would be having a boiler also.
Cheers Chris
  • Replies 84
Cheers Chris
Ok . I have a Burley . That is up there . Also Morso , Clearview , etc etc Do a search there are several posts .
I'm a Charnwood fan, on my second now (house move not worn out) and I can't fault it. The one I'd avoid like the plague is dunsley had one of their boiler stoves and it was shocking.
Cheers Tucky
Tucky
What was up with your Dunsley. We have a Dunsley Yorkshire boiler running 11 radiators in this old listed farmhouse and it is brilliant. Also the Dunsley is approved for use in a smoke controlled area which was an added factor which we had to take into consideration and excluded boilers like the Glenn Farrow.
Tucky
What he said, mine does rads and hot water
