  • Replies 23
Looks really good. I notice there's no bottom rail to the frame - is that to avoid water collecting in the joints? How did you join the middle boards - biscuits?
Door furniture was found on line. Very reasonable. 2 hinges, ring latch and shoot bolt. All handmade. £100 all in.
You don't generally put a full frame at the bottom of a gate or door. You notice the extrusions on the top side of the frame, this makes it much stronger by not having a large mortise cut out, right on the corner.
You couldn't do this on the bottom so the bottom rail is lifted up a bit.
Middle boards are fitted with loose tongues.
Very nice gate, very classy, love the iron work.
Will the Iron work stain the wood when it rains? I have been caught out with iron and oak.
I would have given it a little more expansion room, when it acclimatises in the next wet period it looks like it could bind.
H-A
