MS261 chain break stalling engine
N1ck
  • Replies 30
  • 3 years later...
I tried lots of things to remedy this stalling problem (stalling when brake applied) - including the replacement clutch springs . . . to no avail.
Finally sorted it, once I replaced the needle bearing.
The body of the original needle bearing was plastic, causing the clutch drum to dip slightly on one side when the brake was applied. The replacement bearing is metal = no dipping.
Thank f**k :)
Just make sure the worn out plastic bearing cage hasn't worn a rebate into the crankshaft. You may find that the spur sprockets have come from the factory off centre.
the work one has loads of new new bearings and a new clutch drum but has worn the crank beyond use. not great for a saw thats about a year old. repair shop said it will be about 400 euro to fit a new crank!!!:thumbdown:
