Looking at welders around £150-£300.
I did have a clarkes £90 one and it was so crap and kept blowing up fuses I skipped it .
Also my friend with a car body shop lets me use his but it's no good for steel thicker than 5mm and his was thousands so I'm guessing there must be a nice middle ground reliable general purpose machine that does not use gas in a sensible price.
  • Replies 44
Have a look at a tig/mma set. Get one around 200a should see you right, tig for thin stuff mma for thicker and fabrication.
So with that restriction you are on MMA (stick welding)
Look for a cebora set.
A little inverter will be your best bet. A friend of mine has a Thermal Arc 175 which cost him about £210. It will run happily on 13 amp and an extension lead and will burn a 4mm rod and is easily carried round in it's little case.
I've just used a small inverter welder, seemed to be happy on 3.5 rods from a 13A socket, well impressed at how easy it struck compared with my 13hp genset/welder, apparently it can do tig too.
Looks good , I want somthing that will weld up the job of my farmi winch and still be useful for smaller projects .. I could take them to people I know but with my limited experience want some thing that will do the job properly.
Mig Matty up to 4mm
U can weld with arc under 3mm but easier with a mig or tig welder
Arc is mainly for big welds
Look at the draper range they seam to be ok
