Does anyone on here run a eurocomach/case/new Holland machine, specifically with a flail?
I’m pricing a 2.7 ton with the continuous flow option as I intend it to do a lot of flailing. And some grab work.
Just after people’s opinions on them as there aren’t many about.
Also I’ve requested a standard arm rather than long arm due to stack height with a grab and rotator. Now I’m thinking I should get a long arm as I’ll get more reach to with the flail.
Will the long arm make much difference in my lifting capacity or am I overthinking it?
Thanks
Thanks
If you’re doing a lot of flail work get a tractor much
quicker
Tony flailing with a 2.7t digger is for when you can’t be arsed putting a blade on a strimmer, and tbh sometimes you’d be quicker with the strimmer.  If it’s light bramble and jaggies work in areas you can only get a 5’ machine in with a lot of stones or uneven ground, then use the digger and flail.  If it’s not that then you’ll soon get frustrates with the flail.  More info on you lots of flailing.  Regarding the longer boom, if it’s a zero turn machine it will buckaroo you all day long in the seat and will restrict your lifting capacity.
The only reason I looked at case/NH was the extra pump. The spec says 50ltr constant flow so I can track and flail.
Flailing wise would be brambles and small self sown trees on brown sites so there is normally a lot of contamination in terms of rubbish.
I currently have a green climber lv500 and it’s brilliant, but my business seems to be moving more towards trees than scrub.
im thinking 50% flail work 25% grab work 25% actually digging and grading.
Thanks
The additional pump means nothing, when you track the flow for the Auxiliiaries just disappears.  If you have a green climber you’ve set your bat way to high to go to aflail on a wee digger.  I’ve a Robo flail and it out performs any Flail on a digger over had, even the 13 tonner.    To track and flail you need to go at just faster than not moving 😂. You can’t flail lifting, you have to set high, flail on the down direction and side to side, off the button, lift back up and repeat.  Even changing he’d angle looses power.  My mates selling a Bomford side arm for the tractor for £5k, stick that on a tractor if your jobs allow.  And if you need a digger for digging, buy 1 for doing just that.
19 hours ago, Stephen Blair said:
Got my grapple saw fitted yesterday and only had some saplings to try it on before having to go set my stand up for the local Carving event.
What’s the model omef saw? and price? Did you try any other saw units? Looking for one for my 8t
