Took a while to have them both in the same place with the right attachments to get a shot, but the Liebherr with Extension arm and 22 metre Long Reach JCB with Mecanil head really does make for an interesting comparison.
The Liebherr is just such a versatile all rounder and the extension means it can go out to around 18.5 metre reach up or out, but still be about as easy to transport as a 20 tonner.
The JCB was bought for a specific project that sadly didn’t come, but try and find a decent Long Reach at present so it can stay a bit.
Felling Heads really are taking the job by storm at present across a range of carriers and I’ve had great success with them.
Need a nice small LGP unit back in my life now, some great base machines out there to do them on now.
Eddie.
  • Like 13
What's the outreach and capacity at full stretch on the JCB, just looked at a project itd be perfect for as really can't think of anything else.
1 hour ago, monkeybusiness said:
What sort of radius gives you 2 tonnes plus Eddie? What can the JCB cut and hold 15-20m up?
How much reach and what sort of capacity does the Merlo offer @Gray git
If I need max capacity I’d take the Liebherr and Westtech Grapple Saw, if I need maximum reach I’d use the JCB
If I need fastest cycle times and the ability to reach down slopes then the excavator based solutions can’t be beaten.
If I need maximum height I’d just use the heads on a Rotating Telehandler to get the tops out, and let the excavators pick up the rest.
Horses for courses.
Again really depends on where your reaching too as I have more capacity 8m out and 20m up than I do 15m out and 4m up and also depends on which head I have on as the GMT is half as heavy as the westtech but with far less cut and grip capacity and as Eddie says I can't reach down so useless if the trees are on a down slope apart from getting the stuff about wher I'm set up, anything under has to be chained and lifted.
Beauty with my machine is I have a live load chart screen constantly telling me wher I am and what capacity I have left so I know what's safe to take as a big lump or pick apart.
Depends on what setup is fitted to it, but approx 22 metres and 500kg clear capacity at that reach full 360.
Eddie.
That's impressive!
Quick cycle time too I expect.
Yeah I think you could be heading up our way on this job for whoever gets it as I don't know of any other machines that can do that.
Horses for courses.
What sort of reach (radius) would the Liebherr have 2 tonne capacity then out of interest?
It all depends what configuration you want it in, (there’s many) and there’s actual capacity on the chart and clear working capacity minus the attachment.
I work the solution to the job.
