Hi all,
I have both the above saws and are both very impressive but anyone ported either of them or see any benefits of porting them?
HI ELMS HODGE on here has 576xp ported off pete off here who ports them and the 560 stubby has one and it a very good saw he tells me they will be on soon there on the cizzer thanks jon :thumbup:
  • 2 years later...
Are we takling about porting the cylinders in- and outlets and transfers or "just" muffler modding it ??
Now there is a question, I have done both plus done a pop up piston in addition!
The term "Porting" generally means the ports are widened, flowed and in some cases, the timing changed. Pop up pistons can be machined, squish bands can be machined or simply the base gasket can be left out depending on the saw!
A change to the flow of an exhaust, generally is covered under Muffler Mod (MM).
Some saws benefit from an ignition advance but would add this to "Porting"!
Hi, both the 560/576xp saw go well with a bit of work on them, if you want one doing drop me a PM :thumbup:
I know it's a dolly but you get the idea it's running a 20"bar
Edited by Petemate390xp
  • 3 weeks later...
