  • Replies 88
No, its riveted, the rivet is 7or 8mm but the holes in the zigzag part are 10mm, there are a couple of collars inside which support the pulley. On the ZZHC I have just used a 10mm bolt and some washers for now, if it performs I'll machine up some spacer collars for that too.
To get it off file or grind or saw off the top of the rivet and knock out the rivet with a punch, its tight!
Like the look of that! :thumbup1:
Someone said that the pulley on the zigzag was a bit too small, so this should solve that issue at least.
