  • Replies 21
  Martin B Doyle said:
sorry i miss read the post.
in that case its what happened to mind.
a friend gave me a new latching relay, plug in and off out to work again.
i swapped them around .still didnt run ,think its hodges paddle switch thats @ fault
  Hodge said:
Sounds like the switch, mine used to do it so I changed the switch and it was sound. No doubt someone will say its coz Timberwolfs are crap and you should of got a greenmech😛
Sent using Arbtalk Mobile App
Blimey.
Sounds like an electrical problem the hydraulics for the feed rollers is controlled by electrically operated valves since it will go one way and not the other it's unlikely to be a flow or rpm problem.
Make sure three is a live to and from the switch (when operated). From memory that live then goes to a latching relay, find that and check it, the relay supply then goes to the solenoid valve, check the connections on that and if all that's ok check the coil pack
If you are still struggling I will be back Friday morning, you can bring it over.
cheers andy infornative as always /,
ian, its not mine ,i couldnt lower my self to buy 1, not unless it was realy cheap :laugh1:
Read more
