  • Replies 462
I love mine, but I put a chisel chain on the 200 yesterday so I love it slightly less today! My arms feel much happier after a day of stretching with the 150 rather than 200, could not be without it now
i just bought a bungee strop with it inc ring so clip it up on harness, and the bungee helps to cushion it. Cheap and easy :)
if that thin piece of s***e ring gives out the bodies to flimsy to take a wack from height = total right off
Its so light I can't see that .. Plus if I throw the saw I'll catch it on a strop I and stick it on a harness hook so its close and you really don't notice a 150 on your harness , not cannonball it around the the tree.
But they do break easily.. ImageUploadedByArbtalk1391629022.485339.jpg.6121620b359ec3e820e32815d9ea35b0.jpg
Took mine back to the shop to get the oiler sorted a week ago. Got a call today saying they can't find a problem with it. Told them when I took it in it will work in the shop just raving a bit and not cutting anything, but as soon as you work with it the oil stops. Ended up asking them to google ms150 oiling problem, and then to order a new oiler! Fingers crossed it doesn't take ages to sort!
Had the oil pump changed twice and ended up being told it was down to not using stihl chain oil(which i was using at the time) and that other brand chain oil with too thick, the saw tech told me the pipe that pulls the oil from the tank can crimp if the oil is too thick but am not sure if this is always the case
