I think the whole law about towing agriculture / forestry trailers and machines needs to be the same as it is in other countries, we run the same spec tractors as them and still we have restrictions on what we can do.
1 hour ago, Gray git said:
So could we class a chipper as a agriculture implement so tow a hulking great chipper behind a silages trailer behind a tractor?
You can tow two trailer with a tractor as long as
1, both trailers are empty.
2, both trailers are agri implement.
3, one is a trailer & one is an implement.
You need the middle unit to be rated to tow the rear unit & all weight MAMS MLPM Axle weights & GTW must be complied with.
Yes, given modern agri tractors have suspension & air brakes. One exception that's common in EU. Most operators in the UK may think twice about pulling 20+ton on a hinged drawbar dolly tho:
Whats the restrictions/differences to other countries?
  • 3 weeks later...
6 hours ago, scbk said:
Again, not overloaded, but 2 teenage lads caught on the dual carriageway in tractors (used for xmas trees I think), no rear lights visible
https://www.facebook.com/HighlandIslandsPoliceDivision/photos/pb.289541280823.-2207520000../10158101764130824/?type=3&eid=ARCJ8ChMUprhAhfiqFDp_xouCIKVSwXywopYElmdKYf4Gv45gqJolSEticV6d2knZOOZzdbZnkNEZq5Q
Did they not have the rotating beacons going ?
