Its worth it, if you are in a home you intend to stay in for a while.... Fitting one with a combo style system won't be cheap, you will either need to fit a conventional HW cylinder and neutraliser into which you plumb your gas boiler and wood boiler, or you keep the combi for the HW and fit a heat sink i.e. a double coil Cylinder into which you plumb the neutraliser, and the output to the radiators..
either way wont be cheap.. We used to do about 1600litres of lpg a year, now we do about 250...... and 30 cube of logs....
  • Replies 68
5 bedroom house battered by the wind right on the north east coast and on oil. Since we put our stove in we've dropped our oil bill from £1500 to under a grand for the last 3 years.
I thought about integrating the stove, but we get power cuts too, so decided to leave it standalone.
As has been said above, the house now has a real warmth to it.
And when the power goes out the whistling kettle sits on top beside the pot of soup!
Has to be done Steve ;-)
I have just added up my gas I'll for this year, £1500 ish!:thumbdown:
I have a 2 bedroom semi detached and that's with a log fire heating 2 rooms.
I keep meaning to get a log burner installed, I wasn't going to bother with radiators as we have a combi boiler, and have heard that can be tricky to work together. Although I have heard of a centraliser.
Your thoughts please and an idea of your gas bills would be appreciated if you don't mind sharing:001_smile:
I have a semi 2 bed 9" solid walls, no double glazing and gas is about 500 quid a year. Vented central heating was already here when we bought in 79 but I did change the boiler 15 years ago. As only two of us live here for last 16 years and both work I never thought it worth plumbing the boiler, just have the Jotul and a first generation pellet stove. I burn a fair few logs but less than 60kg of pellets a year (too expensive so only rarely used since I have had to buy them). However I am 350 miles south of you.
I don't think a neutraliser will work unless you fit an expensive heat bank, like a gledhill thermal store. Even then the neutraliser is just a fancy micro thermal store in any case as it depends on a thermal stratification so you could feed the vented side of the store instead with the woodburner.
It is feasible to put a woodburner heated thermal store into the return to the combi but the pump logic would need thinking about and power would be restricted by the size of indirect coil the woodburner would feed. You cannot have a non vented wood burner in your combi circuit.
First thing is to check your contract for gas, if you have been "rolled over" you will probably be able to get a better rate by changing.
Next would be to insulate roof, then walls then floor., trouble is each of these things is regulated by building control now.
she was brought up on a farm & watched her mum mucking out the fire every day ,so kind of put her off any thing in that line
Tending a woodburner in the house is a lot of work and mess, we had indoor wood burners for the first 5 or so years of married life, but it was messy and a lot of work, plus the house was alway cold in the morning.
An outdoor wood boiler gives you all the convenience of gas central heating without the cost.
I no longer have to split logs, no mess in the house and the radiators are too hot too touch, even first thing in the morning.
5kw stove in the front room fans in the loft draw warm air to the ends of the house. cost £400 for stove £150 for fans and insulated ductwork. with wb using about 8 cu metres of wood we use 1000 litres of oil without wood burner 2000 litres plus. but front room is 27deg rest of house 24 deg too hot for blokes. Empty the tray in the wb every 3 or 4 days.
It is a lot of mess, we cut down on that by having log stores built into the walls of the house, we fill them from the outside and remove the logs on the inside..
