Heavy duty landy suspension
tim361
I've been delivering logs in my hi cap landy all week and notice that it sits quite a bit lower when it's loaded. Can anyone recommend me some bits so it carries the weight a bit better. The previous owner fitted pro comp shocks and the springs are orange but apart from that I don't know any more.
Cheers all
  • Replies 20
Cheers all
HI TIM we had pro comp springs now we run the HD TERRA FIRMA HD there very good mate much better then pro comp ones we had in the past all the best jon :thumbup:
I had Britpart HD springs on my old 130 and they were OK for a year or so and then started to sag/soften up.
Went for Bearmach blue ones on the 90 and they've been on a couple of years and sit the same as ever.
For weight carrying though, the standard 130 set up with the helper spring in the middle is about the best there is. Will go straight onto a 110 if you get the cup inserts too.
